The system is 20 years old comprising pressurised DHW tank in airing cupboard, gas boiler in garage and recently replaced zone valve to the hot water tank. The CH controls are firing the boiler OK but the hot water controls are not. I have read the Wiki and FAQs and it seems likely that the problem lies with the DHW thermostat. Can anyone advise how to test this to see if it has failed, before fitting a new one? It is a Honeywell L641A 1005 also marked with T70. Also a similar looking device with a red button is fitted towards the top of the tank: a Honeywell 6190 2004.
The dial on the thermostat squeaks a lot as you turn it with a screwdriver so it is quite difficult to hear the click of the microswitch activating but I am pretty sure that it is not clicking around the 50 degree mark which is where I would expect it to activate with the water now pretty tepid after a cool shower this morning. But I think I can hear it click when the pointer goes past the six o'clock position ie going round from well past the max to the min again.
Any advice gratefully received.
Regards
Graham
Regards
Graham
