No Hot Water
20 Jan 2011
London
Suddenly this morning, I found the hot water flow through all mixer taps in the flat had stopped. The cold flow is OK in the bathroom sink/bath but the shower and the mixer tap in the kitchen (where the boiler is) are both not flowing (either hot or cold). The heating appears to fire up, warm the radiators then not fire up again after say 10 minutes. Is this possibly motorised valve failure? The boiler is a Vaillant Turbomax vuw 242
Do you really mean that there is no water coming out of the hot taps?
Which motorised valve are you referring to?
Tony
Thanks Tony... I just left the house and it looks like there is a burst water main... which will probably explain the lack of water! :confused:
How come the cold flow is working? :confused:
Sounds as if he has a different water main for the hot water and the cold!
