- Joined
- 29 Sep 2012
- Messages
- 6
- Reaction score
- 0
- Country
Hi all i am with out hot water through the hot taps. I have a copper cylinder which does not appear to be allowing water from the boiler to pass through the coil (heat exchanger) the in let pipe is slightly warm to the touch. I suspect the coil is blocked,or air locked. I have forced water via a hose pipe down the outlet pipe in the header tank in the attic to flush through . The vent pipe acted as a over flow and returned water back into the header tank but still no hot water this has worked in the past.
