Hello,
System is a pressurised hot water cylinder (Megaflow) fed from an oil fired boiler. There are two motorised valves in the garage, one for the CH and one for the hot water.
When I put the hot water on on the timer it clicks and the light comes on but neither the pump or the valve actuates and the water in the tank is stoney cold. CH works fine.
I tried forcing the HW motorised valve open and that doesn't prompt any thing to fire into life.
I've left it manually open with the heating on to see if that gets some temperature into the cylinder. The immersion heater doesn't seem to work. Not surprising I suppose as its not been used for the last 10 years.
I'll be getting a plumber out on Monday, but whats the likely cause? Programmer not working or thermostat in the tank not calling for heat?
