No Hot Water
8 Nov 2006
London
Hi All
I have a Worcester EcoTec Boiler and system is sealed with a 3 Port Honeywell Valve. When I turn on for Hot water the Rads warm up but the water remains Luke warm!
Can anyone shed light on this? Is it the Honeywell 3 Port Valve and if so how do I repair / replace?
Many Thanks All.
Need to check the valve out for correct operation, does it move to the correct position when HW is called for? basically check for hot water into the valve and then determined on what's calling, check the pipework out of the valve.
If the programmer is only calling for HW then the pipework into the valve should be hot and the pipe out to the HW cylinder should be hot and the CH side cooler, if not then the valve could be sticking.
Crud check after the summer CH off period...a few sharp blows to the valve body to shake any crud out when hw demand turned on..do not hit the motor head.
Hi Folks
Am fitting the Head assembly on the Hoenywell 3 Port Valve. What position should the spindle on the main body we set to A or B or AB when fitting a new motorised Valve Head? OR does it not matter as the motor will align to the correct position when H/w Water is called or Heating or Both?
Many Thanks in Advance
Thanks Martyg turner and Madrab really appreciate your informative replies.(y)(y)
