My CH hot water has packed up!! If i run a tap and hold the micro switch down on the diverter valve it works fine,I've replaced the diaphragm in the water section but it's still the same.Do i need to replace the diverter valve Which is what i think or is there anything else to try? It would only work with the tap on full last night,then worked perfectly this morning,now nothing.Any ideas?? It's a Vailant Turbomax 242E.
