Morning all
I've got a 5yr old Vaillant TurboMAX 828, on which I changed the diverter valve approx 9mths ago. I am due to fit a Magnaclean + flush out the system within the next few weeks......in the hope that this diverter lasts longer than the last one.
Everything has been going ok until this morning when i turned on the HW tap but all i got was cold water. I left the tap running + went over to the boiler to check it out. Everything seemed fine on the boiler-ie, pressure + no error codes etc. BUT the water temp (a digital readout) showed only 19deg.
Now when the HW is working the boiler 'fires up' + the water temp increases upto + over 35/40deg (depending on what HW temp setting I have). But here the boiler didn't seem to be 'firing up' + the temp stayed at 19deg. I pressed the reset switch + all started to work again.
Is this a one off 'glitch' or a sign of a problem on the horizon? I spoke to my plumber who says it can't be my diverter again, as they usually last a few years on an un-flushed system + my system is fairly clean anyway. As I only had the diverter replaced Dec 2005, i've only had a few months of actual diverter valve use aswell (the heating hasn't been used at all since April 2006). So what's going on?
Cheers
Cheers
