I currently have no hot water or heating in the CH system. When the HW and CH system is turned on, the boiler (Potterton Netaheat 10-16 Mk II) ignites but only runs for about 1 minute before switching off. The pump (Grundfos Super 4 Two Speed) makes a noise and gets quite hot after a period of time and so does the pipes either side of the pump - but only for about 3-4 inches (think the heat from the pump is causing this). The motorised valve (Sunvic DM5601) is working and turns freely.
The room and hot water tank thermostats are both turned up high. Any help or advice would be appreciated as to what the cause might be.
