No inspection chamber before line meets main sewer
19 Oct 2016
I live in a Victorian Terrace which shares a sewer (rain and foul water line) with ten other properties. My house is at the end of this run and there is a manhole cover with a turning chamber in my back garden.
After it turns the sewer then runs underneath my property before exiting into the main sewer that lies beneath the middle of the road. At the front of the property there is no visible inspection chamber or manhole. Is this unusual? I would have thought that there should be a point of entry to clear blockages where the line meets the main sewer. The only point of access is the turning chamber in my back garden which is shallow with no rodding eye.
Thames Water recently CCTVed the sewer and found what they called two 'inlets' next to each other, 12m away from the manhole in the back garden. I put this as just outside my property in the very narrow front 'garden' or possibly even under the public pavement outside my house. I am wondering what these two inlets might be (what historical purpose they may have had) and whether they may be an inspection chamber and a four air outlet. I am wondering whether to excavate to find out. My concern is that they may not be capped off properly and that there is no access here to clear blockages from ten houses.
There is a rainwater downpipe that runs down the side of the house at the front of the property and enters the ground, runs under the front garden, under the pavement and exits at the side of the road - so the two inlets are not related to this rainwater drainage as it drains into the open road at ground level and not the sewer/a drain. Any thoughts on what these two inlets might be, greatly appreciated.
You have a shared drain line, any blockages are down to Thames Water to sort out.
Don't worry.
Andy
My real concern to be honest about it is that there are rats in the sewers (Thames Water have baited and the bait went in 5 days, as did the second lot of bait) and there are rats under the floorboards in my property and the two properties either side of me. This has been an ongoing problem every 2 years we seem to have rats coming back after poisoning the previous lot. I am wondering how they are leaving the sewer and getting under the floor and thought these two inlets might be where they are getting in if they are not capped off.
Thames Water CCTVed to see if the pipe was damaged (apparently not) but they could not see if the inlets had ben capped and will not investigate further (apparently the inlets are my responsibility and they show so signs of rats having burrowed around them).
I appreciate the problem could stem from e.g. 5 houses up the road (the rats are definitely burrowing under the foundations from house to house) but if the inlets are the problem i would like to sort them out for my sake and my neighbours.
I am also just very curious as to what their purpose may have been historically and if they could be a buried IC i'd rather have that exposed and accessible.
I forgot to mention, the pipe is completely straight - there is no interceptor beneath these two inlets and there is no interceptor where the line drops to meet the main sewer. I was surprised at this as i would have thought there would be something to stop rats and smells from the main sewer coming back up the pipe to the shared line. Thames Water will not fit an interceptor here so rats can leave the main sewer and enter the shared sewer line with ease.
Unfortunately you're at the mercy of the water company and as far as work goes if they say they won't do anything then that's it.The problem is they don't have the money to do work cos it's all taken by shareholders,and only a small amount is allocated to remedial repair work.The only thing is to contact the council and if they think that there is a health risk they could do something or force the water company to act best of luck Bob.
Good advice. Also, get everything in writing or keep email copies of correspondence, especially if they start going down the "it's acceptable" route....
Rats can get everywhere.
The capped pipes might be old rainwater inlets and may have been abandoned without capping.
If not too deep you could try digging down to the sewer in front of your house.
Is the 12 m expected to be very accurate? You may be doing a lot of digging for nothing!
12 M does not seem as accurate as 12.3 M !!!
Tony
Tony
