No More Nails Problem
22 Nov 2004
Fife
Help
Doing a bit of repair to a window frame I fixed a couple of small wedge shaped pieces in using 'No More Nails' as I had a tube handy. Note: The repair will be over painted once completed.
This morning I saw that the tube I picked up was for Interior use. Do I need to remake or will the paint protect the bond?
Wood glue would've been better but you should get away with it. If you are worry about it, make a wide V joint where joined then something like P38 filler over it, I know it's for car filler but it does wood as well
