No pilot light
8 Jul 2013
Hampshire
Hi
I have an Ideal Classis ff350 boiler. I don't have any hot water. I can't see a pilot light through the viewing window. When I turn the boiler off and on again apparently the pilot light should light but it doesn't. Absolutely nothing happens. No clicking, no sound. Nothing. Should I hear anything?
Is it possible that a fuse has blown and there's no electricity to the boiler which is why the pilot light won't light?
Thanks in advance for any help you can give.
Jon
Hello again
The boiler has started working. I have no idea how, but the important thing is that it now is!
So now my problem is with my Boilermate 2000.
My actual problem has always been no hot water. I thought it was because of the boiler, but that now appears to be working again.
I've taken the front off the Boilermate 2000, and the correct combination of LEDs light up when I switch the heating on, and I can feel one of the pumps working, which is good.
But when I open a hot tap, LED bar 3 (signifying "Heating pump on") should light up ( but it doesn't) and the domestic hot water pump should run (it doesn't appear to). I'm not sure which of the 3 pumps should be working (the one connected to "primary return (to boiler)", the one connected to "Central heating flow", or the one connected to "Drain"). It is the "Central heating flow" one which vibrates when I turn on the heating. Confusingly (to me) the pipe labelled "Hot supply to taps" does not appear to have a pump connected.
So, does this look like I need a new hot water pump? And if so, which of the three pumps mentioned above is the one that needs replacing?
This all started because I decided to see what would happen if I turned off the mains switch to my Boilermate 2000. That was a silly thing to do in hindsight... I had plenty of hot water until I did that...
Again, any advice will be greatly appreciated!
Jon
Oops, I see that the original subject (No pilot light) has remained.
I'll repost with a new subject heading. Is that the correct protocol?
