- Joined
- 25 Apr 2016
- Messages
- 6
- Reaction score
- 0
- Country
Hi, turned the central heating on but boiler didn't fire up. The switch is beside the timer switch (an old style dial type)
The red light above the switch is not on, so I checked the RCD which had not tripped. Turned rcd off & on a few times but still nothing?
Took switch & timer covers of their sockets & checked for power with electric tester/probe, no power?
Next I turned off power to fuse/rcd box & swapped rcd with another with the same rating & still nothing?
Next turned of power again & I checked continuity with a fluke tester & it was only the earth cable that was ok, live & neutral had nothing?
Checked boiler & as I thought no power to it, checked reset switch & that was ok?
So I'm thinking there must be a break in the cable from the rcd to the switch/timer but I'm not 100%
The switch is only 6ft away from the rcd box & don't have any rodent problems.
Has anyone had the same or similar problems like this?
Any help or advice will be much appreciated
