hello,
when I went to get in the shower this morning, the water didn't heat up.
there is a pull string switch in the bathroom that turns the power on to the shower - this has a light on it but it did not come on when turned on.
I've tried changing the 30A fuse in the consumer unit but that didn't help.
strangely, the shower worked ok 10 mins beforehand when the missus used it. I've lived here for 10 years and never had trouble with it before.
the fact the pull switch doesn't light up suggests that maybe the pull switch is not getting power or is broken? the manual shows this as being wired into the feed to the shower, which seems logical.
the shower unit is a Mira Technology Essentials, according to the manual. Unsure if 7.5, 8.5 or 9.5 kW.
any ideas what could be wrong?
thanks!
thanks!
