Ive just installed a 8.5kw electric shower the cu has a rcd unit and im usein a 40amp mcb unit useing 6mm twin and earh ive fed this to a double pole neon pullcord switch then from there connected to my shower.
All connections are tight and useing a tester screwdriver i have power to both switch and shower! The problem is the shower power indicator is not working ive even tried connecting another shower up to see if other was faulty and still no light comes on the shower unit, what am i doing wrong and is there anything ive missed? Any ideas would be greatfully accepted.
