A family member just moved into a brand new block of rental flats. The lounge is wired for Sky + / satellite.
I made up a 6meter satellite lead using Sky branded cable and connecters, but no signal is found. I tested out my cable with a multimeter and there are no short circuits (I've made loads before so I didn't expect this to be the issue).
I also didn't get any tingle from the cable when it was plugged in, which I usually do with communal systems.
What other testing can I do? I have a sat finder, if I connect that to the socket, should it show a signal, or does it not work this way with distributed systems?
We want to be sure its not a receiver / wiring fault before contacting the landlord company, as if it isn't a system fault they will charge.
Thanks!
Tim
Thanks!
Tim
