Hi all,
SWMBO became bored with waiting for me to redo our downstairs bathroom so she commissioned a plumber and the tiler that he recommended.
I used my Festool masonry renovator to grind away any tile residue and the existing water based eggshell on the walls.
Once the plumber finished I PVA'd the chases and filled them with bonding plaster. I made sure that I didn't get any PVA on the surface of the old plaster, I didn't want to create any potential problems for the tiler.
The tiler started yesterday. Thus far, his cuts and levels seem good. I am however concerned that I can see no evidence of him having used any SBR on the walls. If I lick my finger and touch the walls just above the last row of tiles that he has fitted, the plaster turns from a light dusty pink to a dark pink.
It may well be the case that he pre-wet the walls before applying the adhesive but is that really deemed to be acceptable? Given that I had grinded the walls, the finish was extremely porous, ie more so than when the room was first plastered.
The walls are thermolite with a cement screed and then a plaster skim. The tiles are 600*600, 10mm porcelain. I forgot to check to see which powdered adhesive he was using.
I had assumed that he would tank the shower area and "shampoo bottle recess" but I guess he isn't planning to...
