no sound
12 Jan 2008
Essex
I am trying to sort out my toshiba A100 laptop,about 6 months ago the sound stopped.
I try using u-tube
If I try a cd
It says
it cannot play as there is a problem with the sound device
I havewindows xp sp2
I tried a system restore , but it would not restore for some reason, and I want to avoid that now if possible.
I have tried the volume wheel on the front, and I have no external speakers either to try.
in the control panel,under sound and audio
It says NO AUDIO DEVICES
and the screen is greyed out
Not sure if that is relevant
I have noticed it dont bleep now either when you do things wrong
Is there an easy way a novice can diaagnose and repair
Many thanks
If you go to your control panel (classic view), system and find hardware device manager, can you see any yellow/black exclamation marks?
Thanks for the reply
no theres not any :!:
I clicked the sound devices whilst there, this brought up the same greyed out screen I mentioned above
Is it disabled in the BIOS?
Have you checked:
control panel >system > hardware > device manager > sound, video & game controllers
Is a sound card listed? Is it disabled? right click and so a "scan for hardware changes".
If you have the drivers, try an unistall, scan for hardware changes and re-install the drivers.
Is it an on-board soundcard or does it also have a 3rd party sound card built-in?
If it's any consolation my sound hasn't worked in 2 years on my laptop -grrr...
:oops: :confused:
I will right that all down
try to decrypt it
Try it
then return when i have b***s it all up :!:
Thank you
Right
under hardware
matshita dvd ram
location 0[0]
device usage
use this device(enable)
IT SAYS
this device is working properly
AND
audio codecs sound,vid
legacy audio drivers sound,vid
media control devices sound,vid
legacy videocapture devices sound,vid
video codecs sound, vid
ALL THESE ARE
location unknown
Device usage box blank and greyed out
THEY ALL say this device is working properly
The properties box seems to expand each into about 10 other components
This is now sorted out
Used product recovery disc and it sorted it out
thanks
