My hot water cylinder (gas) is such a tight fit in the cupboard that there is no way I can fit a hot water jacket and close the door without it opening...
I could fit a bolt to the door and that would secure it (its one of those latches that secures by a spring loaded ball and thus just keeps springing open) but that means the insulation is heavily compressed against door and cylinder.
I also trailed insulating the cylinder with thermal wrap. It looked like a cool darlic when complete but then I saw online that all foil based wraps are for electric heated gas cylinders and took it off (I was unsure if it was safe).
So my question is, should I bolt the door closed with the hot water jacket on? Or should I dress it up like a shiny darlic in thermal wrap (is it safe?)? Or is there another product/solution I can use in these very confined spaces?
All help much appreciated.
