no surround sound
11 Jun 2005
Cambridgeshire
hi all, I havent had my TV hooked up to surround sound for ages since i lost speaker cable connectors while decorating and maybe ive not connected correctly anyway...
the S/S is ok when playing cd's/dvd's but not thru TV
I have a scart from DVD player to TV at the back of the DVD there are
loads of female connectors showing audio in 2 reds and 2 whites
at the back of the sky box i have the same
at the back of the KDL 40ex 503 TV i have 2 green ( p/b cb and p/b cr ) and also 2 white and 2 red audios so do i need to buy some cables to connect whatever to whichever :) Thanks P M
EDIT oh dear should have posted in Audio/ visual will some clever person please move it for me :oops:
Are you using a separate surround sound amplifier?
If so, each source (Sky Box, DVD Player etc) needs to be connected to the relevant input on the amplifier or Surround Sound supply unit.
It's the source that gives the audio track rather than the TV which in most cases, for all intents and purposes, is a visual display unit only.
Example, I use a Yamaha RX amplifier. My DVD player is connected to the TV via HDMI that runs in through the amp, so HDMI from DVD to Amp and then HDMI from amp to TV... so I get audio and video.
Sky box is connected to the amp via optical cable to the amp and SCART to the TV.
