- Joined
- 23 Jan 2006
- Messages
- 1
- Reaction score
- 0
- Country
Hi All,
I've moved into a house where the CH is based on an old Thorn Apollo boiler and appears to be the standard wet system i.e. 2 pumped circuits one for HW and one for CH.
But there is no vent pipe, just a feed from a header tank into the system. There is air in the system and banging noises when CH is in use so I suspect this may be at least part of the problem. Is this lack of a vent pipe usual? Can the feed also act as a vent?
One possibility is that I install a vent pipe to try and sort the problem but where should it go? The boiler is downstairs and the pump and HW tank upstairs. I could easily put a vent pipe in the system as it enters/exits the HW tank. Easiest location is as the pipes leave the tank....I could just put a 'T' junction in at the 2port valve and vent the system up into the attic and across to the header tank.
Does this seem sensible and/or does anyone know of information regarding design of CH systems.
Thanks in advance,
Ian.
Thanks in advance,
Ian.
