Hi folks,
have an Istor HE325 boiler in a new build. Most problems sorted but 1 remaining... After the boiler has been on for hot water when the first tap is opened to get hot water a very loud vibrationary noise comes from the boiler. On further inspection the pipe from the DHW Expansion Vessel was vibrating and as this stopped vibrating so did the noise.
This is perfectly reproducable so is a constant source of annoyance. I have had engineers out to see the issue and the best they have done is to lag the pipe with insulation.....still the same vibration and noise just doesn't clatter against the front cover of the boiler which it didn't before as I had remove it.
I guess it's some kind of air lock but I have no idea how to get rid of it. Any ideas welcome.
Thanks, Paul
Thanks, Paul
