I have a Potterton Promax combi HE Plus, which is about Three years old.
The central heating appears to be fine, however when I run the hot water I get a a horrible knocking/banging sound from inside the boiler and the pressure fluctuates between 1 and 1.5 bar, the noise stops as soon as the hot water tap/shower is turned off and the pressure immediately stabilises. This does not happen all the time I would say about 1/3.
My questions:
Is this likely to be an air lock, if so how can I remove it from the system?
Could my pump be at fault, should I call an engineer?
http://www.youtube.com/watch?v=tyPWUU2DVdk
My questions:
