hi there
the servis washer dryer 900 must be at least four years old now and has started to make a lot of noise mainly when emptying after a spin, it sounds like the bearings are going, but having taken the back off and spun the drum by hand it does not appear to be the motor that turns the drum,
so questions:
could it be the motor but unable to spin it fast enough by hand to make the noise,
if it is not the motor could it be the pump,
how do you tell what the problem is and once identified can you still buy the parts
hope you can help
Ivanm
so questions:
hope you can help
Ivanm
