I have constant flowing noise around the house of running water - any idea what it might be? There doesnt seem to be any leaks anywhere. Could it be an air block? If so how do I get it sorted? Thanks in advance.
AB
If after checking that none of your ballvalves are passing/overflows running then it may be that you have an underground leak on your main water pipe, sometimes the sound travels through the pipe into the house,get your local water authority to come and check for you with a listening device.
