Hi Boys.
Right, my neighbour's central heating is controlled by a fairly old boiler (which looks like a small hot water tank) and a pump. When the heating /hot water is on and the pump is working, both the pump and the pipes which run off it, vibrate. The noise from this is minimal like a low hummm in my neighbours house but the pipes sit on our adjoining, 2 layer plasterboard wall and the cavity must be amplifying the sound because in my house, and specifically behind my bed, the noise is quite loud.
My neighbour is helpful and co-operative and so before i attempt to insulate walls and add soundproofing, i wondered if there is anything i can put on the pipes her end to stop/absorb the vibrations?
I haven't slept properly in ages so any help or advice will be very greatly received.
Thanks.
Thanks.
