When I flush my toilet, as it starts to re-fill, there is vibration from under the floor and a noise which can only be described as a cross between a ships foghorn and a very poor trombone player, who only knows one note This lasts for about 20 to 30 seconds and then stops. If I turn one of the taps on in the bathroom, this will also cause the noise to stop.
I have a ball-o-fix valve on the cold water supply pipe to my toilet and last week, I turned it to reduce the flow of water to the toilet. This stopped the noise until yesterday, when it started again.
I removed the cistern ball valve this evening, took it to bits, cleaned all the components and put it back together again. No noise for oh at least three flushes but then the noise returned.
Do I need to just buy a new cistern ball valve and will this stop the noise occuring?
What is the likely cause of the noise?
I've heard of Torbeck valves. Should I buy one of these instead of a standard cistern ball valve and what are the benefits of these?
I would appreciate any responses. Thanks.
Mr M
Mr M
