Noises and cut out on Potterton Combi Boiler
10 Mar 2004
Hi
Our boiler was making a crackling noise about a couple of weeks ago. I prayed the problem would go away and it did.
However, now we have a problem with the boiler cutting out. The pilot light stays on but the main plate (I don't know the techie name) flames go out.
When I give the front of the boiler a knock, it seems to get it going again
Please can anyone help
Breezer,
Thanks for replying.
Here's a little more info
1) Boiler make / model (gas or oil)
Potterton Prima F Gas Boiler
2) What is / is not happening
The main burner goes out when the boiler should be running. Sometimes there is a loud crackling noise coming from the boiler
3) Has ANYTHING else been done / changed recently
No
4) When did it (problem) start
About 1 week ago
5) When does it happen? eg, heating coming on or going off
Intermittently when the boiler should be on
6) Anything else you feel may be of relevance
I have bled the radiators. The radiators/water are hot when the burner is on
I would say that you have a blocked gas jet going into the main burner this is easy to cure but get the pros in because of the gas aspect
Pete
