Here goes and I hope this all makes sense...... I have a gas fired boiler which heats the hot water and heats the house via radiators (expansion tank in the loft) and approx once or twice a day generally when the central heating is on pipes in the loft start gurgling very loudly and this then travels down to the boiler, the only way I can stop this is to bleed 1 or 2 of the radiators upstairs (with a lot of air coming out), however within half an hour it can all start again.
To complicate things even more this morning with just the boiler on heating the hot water tank (central heating off) the noises started again and I had to bleed one of the radiators 4 times (each time I'd done it the problem was solved only for it to start again!), even though the central heating was off!
I've emptied the system on a number of occasions whilst I've been diying, removing radiators etc. I've cleaned the system out then put inhibitor in. The last time I did this was about 2 weeks ago and the noises stopped for about a week, unfortunately to return. One point to note is the water tends to run pretty clean when I drain the system but when I take any radiator off the water is black and full of gunk!
I have a baby on the way in a few months and need to keep noises like this to a minimum.
Look forward to hearing from anyone who can shed some light
Regards
Mark
Regards
Mark
