noisey boiler
2 Nov 2008
Manchester
please,please help , :cry: :cry:
we have a IDEAL MINIMISER SE boiler that has a mind of its own, every 30 mins or so boiler ignites and bangs and clatters releasing water into tank in loft(heating and water turned off).
we had it serviced last year (drained and sentinal x100 added) would it solve the problem by adding more sentinal x100, if so should it be added in the tank in the loft?
thanks in advance for any replies.
sounds like it needs a good service and possibly new electrodes.
could be a faulty motorised valve causing boiler to fire when valve shut - causing overheating.
but do the end switch(es) open when the valve(s) close :?:
if one of your 2 port valves are "stuck shut" - and sending power to the pump and boiler then this would explain for them being constantly on - but this shouldn't make the boiler overheat as the stat (boiler) should cut out when satisfied.
dont know why water is pumping over though.. could be many things.
