Hi, I have a problem with an old Glow Worm Fuelsaver 80F - circa 1988.
Whenever the timer switches the system off or the room stat reaches temperature there is a load banging noise followed by a discharge into the header tank via the expansion system. However the noise does not occur when the boiler shuts off when it gets up to to temperature.
I have noticed that when the problem ocurs the pump is not running which I thought might be the heat overrun circuit so I replaced the thermostat control unit which also incorporates the pump over run circuit on this model of boiler. I have also replaced the overheat thermostat although I am pretty sure this would not be the problem. As a last resort I replaced the main controller board but this did not improve things either. All the radiators get hot and I have put some Sludge remover in the system. I have now run out of ideas, does anyone have any suggestions please? Many thanks.[/b]
