noisey pump/banging boiler no heat
11 Dec 2007
Derbyshire
we recently had to have the thermo couple replaced in the boiler, the central system was off for around 24hrs and when we restarted the system we could not get the radiators to come on. after cosing them all off and opening them up in turn they evenually came on.the system went off at night but when the system restarted in the morning the pump was noisey ( whining ) with an occasional bang and there was also no heat at the radiators. I turned off the system for around an hour a turned it back on again, all seemed to be fine, in the evening the pump again became noisey followed by the radiators going off again. we are occasionally getting a bang from the boiler as well. Any ideas any one!!!
Pump has been running dry by the sound of it and they don’t do that too long before keeling over. Make sure all air is out of the pump and the pipes for that matter when you get the new one
Would not hurt to check for sludge with open system
also verify that you have plenty of water in the system
if you bleed the highest radiator, water should squirt out vigorously.
the cold feed is often blocked with sediment
sometimes the F&E tank is empty e.g. if the ball valve has jammed
