noisey trv
m-k
21 Oct 2007
hi just had complete combi system fitted worcester 32cdi inc rads with bulldog trv s when system working trv s noisey is this normal or it is because they cheap ones if i need to replace to stop noise which ones do i buy ???
what adjustment will be needed its the same on all of them ???
Bulldogs not a bad valve and don`t usually play up let alone all of them what sort of noise are you getting, occasionally you get a clunking one as it shuts
like a gushing noise through the trv s when heating kicks in boiler set to economy all trv set to hi they all noisey when i turn one of the trv down just a touch noise stops turn back up and gushing sounds again
