It’s‘ probably a coincidence but ever since I had an auto bypass fitted (which required some pipework alterations in my airing cupboard), I’ve been getting a vibration noise when my programmer instructs my Honeywell 3 way port valve to switch from Heating only to Heating and Hot water. My plumber replaced the auto bypass valve but it has made no difference. So I believe it’s either coming from water turbulence within the altered pipe work or, the 3 way port valve itself.
The vibration starts almost immediately the programmer calls for hot water ( in addition to Heating) but lasts only a couple of minutes. I can stop the noise by moving the lever on the 3 way valve to the “ manual” setting but it comes back when I “unhook” it and it returns to “ Auto”.
I’ve replaced the motor but that made no difference. Before I call back my plumber do you think I might get away with just replacing the valve head or do you think the whole unit needs replacing and/or pipework altered?
