I've posted before about a similar problem. When we moved in the boiler was kettling a lot. Turns out the radiators were not balanced properly and closed down too much. We have TRVs fitted where appropriate and a honeywell autobypass.
The boiler is a Baxi Solo2 PF60 with the output set at 3.5, pump speed is two. Everything runs fine, it's really quiet and the house heats up nicely. There are 16 radiators and 5 have no TRV.
However, when the MV closes there is a very loud whoosing noise of water - not sure if it's acutally water noise or boiler kettling or both. It makes this noise regardless of what setting the auto-bypass is set to (currently .25).
I can post a pic of the pump/valve set-up if required. Any ideas as you can hear it all over the house?
