noisy check valve
15 Mar 2006
London
Hi - I have just installed a mixer tap. The hot is feed by low pressure gravity system (head of 6m) and the cold from mains. Despite the pressure differences the tap works fine. However I was concerned about the cold running up the hot pipe so I fitted a single check valve. The issus is that when the hot tap is just on - there is a vibration from the check valve (I assume the valve is rapidly opening a closing) - Is there any way around this - eg a low pressure/more sensitive valve?
Appreciate any help
Thats unusual but as you suggest another valve might not make the noise.
Its generally bad practice to have unbalanced supplies though!
A pressure reducing valve on the cold set at close to the static head of the hot will usually work wonders.
Tony
Thanks Tony - so step one - I shall try another check valve.
Unfortanely the whole house has unbalnced supplies as the cold is direct to every outlet.
Sorry, I should have said another design of check valve.
With a plastic plunger as they are lighter ( although few domestic valves would usually be found with brass plungers ).
Tony
Ok thanks.
I read somwhere about taking out the spring - have you done that before?
It is unusual for the hot and cold to mix within a mixer tap as as they usually have a fluted spout to prevent this, so that the water only mixes as it leaves the spout. Are you sure that you have installed the check valve the correct way round?.
I have the valve in the correct way, I understood that the mixing takes places within the tap, in a modern tap, and that creates the risk of cold flowing up the hot. I guess I could fit a PRV to the cold and then take out the check valve?
