Noisy cold water tank refill
23 Aug 2013
South
Moved into our first house and finally got round to buying another waterbed, upon filling for ages (hot tap) the pipes in the airing cupboard started making a god awful noise, like vibrating and very loud, made the misses cry!
We done so investigation work, checked the pipes all clicked in.
I then lifted the cover to cold water tank and pushed down on the float valve slightly and aha the noise is coming from the valve thingy.
If I lift it up to stop water flow no noise, push it down and Thor is nearby.
So is it a new valve and bobs ya lover?
Part 2 float valve.
I would also double check that the pipes are clipped properly where you can.
