ME again ,update i still have this dam noise,i've had 2 new linkage arms fitted aswell now ,,gr, gr, gr,
hi hope someone can giveme someadvice..i have a R reg 1996 escort lx, 1600 zetec engine, the engine runs lovely and quite and it has only done 54,000 miles the problem is that when i'm driving along a smooth road i can't hear a noise..then if i go over a pot hole or some form of uneven road i.e were they've replaced tarmac e.tc i get a clunking type of noise quite loudly it seems to me as if it is coming from the front of the car "MAYBE CENTRAL" ?.
NOW I was told it was the wishbone arm so i had a new one fitted, still i had the noise, then i was told it was the drive shaft cv joint or something like that? so i had a complete passenger side driveshaft fitted and still i have the noise ,now i am on a tight budjet so i can't afford to keep going down the line of trial and error .........can anyone tell me what this problem could be ,,as i have now been told it could be the carrier bearing in the gearbox..if this is so how can you tell if it definatly is this as i don't want to be going to the expense of this to find out i still have the annoying noise!! ..the car starts first time in amorning with no funny noises and there is no screeching coming from the gearbox and i can get my gears like normal with no problems,,hope this info helps with the solving of the problem if someone can hep?
THANKS ANG
Back to top
THANKS ANG
Back to top
