M
M1AYM
Hello, My central heating seems to have a juddering sound that reverberates around the pipes in the house. I’m fairly convinced this is due to the pump as increasing the speed increases the noise level of the judder. My central heating service contractor advised it was due to hydrogen in the system. Since then I’ve added cleanser and drained it and refilled with no difference. The contractor will not change the pump for noise unless its faulty. I’m currently running without inhibitor until I resolve the issue as its likely I will have to drain again. I’m also running the pump at its lowest of the 3 speed settings to get some sleep.
As an electronic systems engineer, my feeling is that it could be an electrical winding in the pump motor that has gone open circuit and therefore a phase is missing and the motor is stalling in its rotation though I’ve not a lot of experience with AC motors. The other thing I am experiencing is that the when the pump has run for 5 minutes or so it switches off for 2-3 seconds then re-starts. I wondered if this was symptomatic of the same thing or if the boiler control to the pump was designed to do this?
If the capacitor has failed in the pump I would imagine the pump would not start or could this be the possible cause ? Has anyone come across these symptoms before?
The pump is a Grundfoss 15-60 fitted to a house built circa 2002. Having watched a plumber try and replace a pump in my old house, I’d rather not have to replace the entire pump unless its absolutely necessary.
There appear to be 4 alan bolts holding the motor body of the pump to the casting attached to the pipe. Does anyone have experience of separating and repairing/replacing the motor body its self in situ and is it possible ?. Is it possible to change the bearings by stripping in this manor ?
My fear at attempting this is that there will be some gasket behind the pump body which is probably not available as a replacement part and therefore if it leaks afterwards I would still have to replace the entire pump. Any ideas gratefully received…
