I have a Potterton boiler and iam having problems with noisy radiators especially at night.I have bled the radiators upstairs as this is where the noise comes from.I can only describe the noise like waves of water bubbling through the radiator.Any ideas?
If you've bled all the rads and there's still air noise in the system - you've got an air leak. Has anything been changed recently, especially near the pump? In most open-top systems, the pipework and fittings near to the pump inlet are under suction, so air can easily be drawn in.
