Noisy hot tap
23 Feb 2007
Clwyd
The hot tap in our bathroom basin worked fine until a few months ago when it started making a loud rattling/vibrating noise when it is opened. The sound stops when the tap is opened to approx. 75% or more of the maximum amount. I've also noticed that it doesn't make this noise when the toilet cistern is refilling.
For information the hot supply is from a combi and no other hot (or cold) taps in the house have this problem.
When the noise first started I changed the tap headgear as I presumed this was the problem. I found that the old rubber washer had partially disintegrated but it soon became apparent that the problem still persisted with the new headgear in place.
I'm wondering if this problem is because the tap can't cope with the pressure and this is what causes it to shudder.
Any thoughts on what might be causing this would be greatly appreciated?
Mike
Thanks for your reply.
The washer was changed at the same time that I changed the headgear.
Mike
Try checking the tap body again. Did you fit the correct tap washer?
Okay, I will double check the tap body and washer to make sure.
I did wonder if a bit of the old (disintegrated) washer had got stuck within the pipe or valve seat and was interfering with the flow through the pipe.
Mike
