Noisy hot water
28 Oct 2013
Hertfordshire
When my system is cold and the timer kicks in and turns the hot water on it makes quite a bit of noise, gurgling and bubble noises but as soon as I slide the control over so that both the hot water AND the heating is on it all goes quiet then if I slide the heating off again and just leave the hot water on I get the noise again. Once everything is warmed up it seems to quieten down. Any help would be much appreciated.
1) Air trapped in cylinder Coil
2) Lack of water flow though boiler when in hot water only mode
perhaps some pictures of your system layout would be useful??
Thanks for the quick reply. Complete novice here so when you say a picture of my system layout do you mean this:
[/img]
Also, any idea what the small yellow box is front right? I think it's something to do with the power shower but it isn't connected to anything.
issue with the hot water We have a standard hot water system heated by a gas boiler and the central heating system is a bog standard one with header tank etc and when the hot water and the central heating are on at the same time it is as quiet as a mouse.
The issue is when the hot water only is on it is making a right old racket with I think a lot of air trapped between the boiler and the main hot water tank. Where would I bleed this air from?
Anyone else got any ideas.
