Noisy new mixer tap
20 Oct 2008
Sussex
I have recently moved and had a new combi boiler and bathroom suite fitted. The mixer tap in the bathroom makes a loud noise when it is set half way for flow or halfway for temperature. When it is on full flow, the sound almost stops. You can hear the noise from all over the house. I have tried to alter the mains water pressure but this does not work. The tap is designed for low and high pressure systems. The tap was not the most expensive tap in the world so not sure if that has anything to do with it.
I have a mixer tap in the kitchen which has not been replaced and that is fine.
Would appreciate any suggestions.
