Noisy Pipes, Help!!
28 Feb 2007
London
I live in a ground floor flat in a converted house. In the last 3 weeks I have been subjected to intermittent noise from the upstairs flat.
The majority of times when the tenants have a bath or shower I hear a banging sound from the pipes in my bedroom which can range between sounding like a electronic screwdriver to an industrial sounding pneumatic drill and is waking me up at all hours.
The landlord who doesn't live there is refusing to acknowledge the problem as the one time they came round the noise wasn't present. This noise seems to be getting worse. Any ideas on what this could be?
Just before the noises started they had a new radiator installed. Could this have anything to do with it?
Could this still be water hammer when the flat does not have a tank? I contacted a plumber and that his what he said.
There was recently a lot of work done by Thames water replacing pipes in the street. Could this have had an effect on the water pressure and be the cause of this noise? As the noise only happens when the hot water is turned on could this not be a problem with the boiler?
Thanks for any help
Maybe the trv on the new rad is not bi-directional and the cheapskate that the cheapskate landlord used to do it fitted it on the wrong end.
HI
common causes of water hammer
1.loose/faulty washer in the mains cold water stop tap
2.loose/faulty washer/diaphragm in the W.C
3.loose/unsupported pipes
4.too much water pressure(less likely)
5.loose/faulty washers in the taps
start from N.1 change/replace parts if necassary
