Noisy pipes/radiators
11 Jan 2005
Help!
Had a combi boiler installed a few months ago, since then have been having 'clicking/creaking' noises from under floorboards and from radiators. It is very difficult to identify where noises are coming from. I have replaced 1 radiator. I also took up floorboards & packed under pipes, etc. This seemed to help for a while, but we are now back to being woken up every morning. Would it be worth replacing some of the copper pipe with plastic?
i have same problem,combi boiler,system was quite until i drained system to replace a rad now get clicking and creaking every time heating comes on..have insulated pipes,bled rads even drained system again,i know how you feel...if i get any more advice will send it your way...
Stop being so fussy and live with it, you sound like my missis, it's a good sign the heating is working, you would be moaning if the radiators were cold.
check if the rad brackets have the little plastic (1/2 inch long "cussions") that sit on the bracket hooks to prevent metal-metal contact. The clicking could be coming from here when the rads expand.
