One other thing I should have mentioned is that when you turn on the cold water tap and let it run for a while which is next to the toilet the toilet it gets rid of the noise
It sounds very much like your supply upstairs is fed from the cistern in the loft. Renew the ball valve and float (high pressure part 2 should only cost £3) and this should cure
