Have recently moved into a new house and the radiator in our master bedroom clicks like hell when heating up and cooling down. Searched on here and tried everything below but nothings worked. I’ve traced the sound as best as I can, and whilst I can hear/feel it mostly from the TRV pipe side it’s genuinely loudest in the radiator itself. Is there a possibility it could be the radiator unit??? - I’ve tried:
- Pipe from the TRV side looked under floorboards and there’s no obstruction from the floorboard/wood and as far as I can see the pipe isn’t rubbing anywhere,
- Removed and swapped the TRV with another from a different room. No difference.
- the noise is still there even if the TRV is set to 0 or to 5. Which makes me think it’s the pipe, but then as above can’t see any issues or obstructions with the pipe.
- turned lock shield on other end of the radiator to almost completely closed so the radiator barely heated up. Same noise and noise level.
- Brackets on radiator are quite loose to the point the radiator can move up and down so it’s not that tight. I can’t see if there are any plastic brackets (photo attached sorry it’s filthy!) but the noise is concentrated so if be shocked if it was an expanding issue rubbing against the bracket.
Not sure what else I can try. Would next step be replacing the whole radiator? It is quite old and the only other thing is the bleeding port it has rusted to the point where it’s difficult to lock back up again and being bled (though doesn’t leak water so much be closed)
