Hi everyone, hope you can help.
I recently moved, the boiler and the central heating pump at the new house made some truly terrifying noised for about 30 minutes when it first started (water was also coming out of the expansion pipe into the small tank in the loft). A few weeks later the central heating pump stopped working all together and I called in a plumber.
He said that the system was sludged up. So he replaced the pump and rinsed the system.
At last, no more rude awakenings at 6am!
But, after 2 or 3 weeks the radiator closest to the boiler started making loud gurgling noises and now sounds more like a tricking waterfall. The radiator directly above it has started sounding like a water feature too...
So, I tried to bleed them to no avail. Air came out for a few seconds and then water started spluttering out. Should I keep bleeding through the spluttering or is that enough?
I have read mention of needing to rinse again after the cleaning agent has been in for a couple of weeks - could that be it?
Katie
Katie
