Hi, please can anyone offer any advice.
Earlier this year I moved into a council flat with a Worcester Heatslave 9.24 combi boiler which was installed in 1988. There are 6 radiators (2 with thermostatic radiator valves).
The problem is all the radiators make a constant noise (like wind blowing through them). The noise is even louder when a radiator is turned off, and is very annoying. Even when the heating goes off at night the noise continues for 20-30 minutes.
Early this year I had a new pump fitted privately (the council are only carrying out essential repairs as the heating is due to be replaced in 2007/2008). This cured the noisy boiler, which had sounded like a train chugging along! The engineer also put inhibitor?? through the system. For a while the radiators were much quieter. Unfortunately, now they are as bad as ever. A council engineer and two private engineers have said nothing can be done.
I would like to know if this is a common problem with combis or if it is because the system is old. Is this kind of noise usually considered "normal"? I've never lived anywhere with this type of heating or heard this noise from radiators before.
Any suggestions or advice would be much appreciated. Thank you.
Imogen
Imogen
