I have a low level toilet in the bathroom. It's always made a bit of noise immediately after you flush it. Last week I took out the pan to lay some laminate flooring and then replaced it when done. I turned the water off at the mains (no local isolator) and opened the cold kitchen tap in case the mains tap wasn't totally off. Now when I flush, it sounds like the QE2's fog horn going off. The noise is only there for about the first 10 seconds of the flush, then it quietens down.
I did search the forum for an answer but there was nothing conclusive. If it's air in the pipe, how do I shift it?
Not sure if it's important, but just in case, we have a combi in the bathroom too.
