Just fitted a new toilet but its making a really growly noise (sorry not technical) when flushed but if its flushed again within 2 mins it doesnt make this noise. Ive bled all the radiators as it sounded as if there was air in the system. Any suggestions please?
With the water being switched off i just bled the radiators as par for the course. As the sound is so loud i wasn't sure if it might have been air in the pipes somewhere, worth a try but never worked.
Hi there it is when you press the flush, it only last a few seconds but sounds like furniture being pulled along a wooden floor. We took the old toilet out and put a new one in, no pipe work replaced.
Have you got high cold water pressure? Did the filler valve come with a pressure reducer? If there is an isolator, try turning that towards closed and see if the noise changes/reduces
